1-2 shift almost always clunky.
Chicago
Recently traded in my 3 banger fiesta for a used ST.
Car runs great. However, the 1-2 shift is always very clunky unless I ride the clutch a good bit and give it more gas than I need to for any other gears.
Is this just me being a shitty driver, is it rear motor mount, is my transmission messed up, or is this just a thing in the ST?
I've got 6k/5 months left on 3/36 fwiw. Taking it in monday to have a super shaky side mirror fixed.
Thanks!
Wichita
A Cobb or other aftermarket rear mount will make a huge difference in shift quality
me32
fairfield
The mount has a lot to do with it because the engine moves under acceleration.
L
Chicago
Alright, thanks. I was hoping/thought that was the answer.
me32
fairfield
There are a good amount of option if you choose to change it. I still have my stock mount on with 60k miles. No issues, tranny shifts fine, just need to make sure the clutch is pressed all the way.
L
Chicago
Clutch fully depressed. Clunk is on release/catch.
me32
fairfield
Correct still the mount thats part of the problem. Mine does it too but i dont consider an issue because it doesn't effect the reliability of the car. Tranny still shifts fine
Zormecteon
Kelso
I've found the step from 1st to 2nd is rather large and I have to wait longer for the revs to fall before letting out the clutch on that shift than the gears.. Watch your tach and see if you're letting out too soon? (the car has shift assist, in that as the revs fall, they will hesitate at the proper point for engaging the clutch.)
L
Chicago
Huh, that may be it. When I'm "riding the clutch" on that shift it is smoother, but I'm also taking long. Thanks for the tip.
L
Chicago
Consciously let the revs drop on 1-2 today, no more clunk. Makes me really think motor mount would help. thanks for the tip!
Charlotte
Motor mount does nothing for this clunk. Only high rpm shifts really. I bought it for this reason but it didn't sort it out.
Sent from my XT1064 using Tapatalk
Arlington, VA
What boombots said. The 1-2 shift is just clunky on this car because of the gap in ratio and heavy dual mass flywheel. If you want it to be smooth, you gotta take it easy letting out the clutch and getting back on the gas. The RMM may help slightly during daily driving, but it is more to keep the mount from bottoming out on quick shifts at high RPM.
Zormecteon
Kelso
For me, the result of the RMM was that under hard acceleration in 1st and 2nd gear, the car no longer "scrabbles", that is looking for traction first on one side then the other. It's just more planted. Shifting is of course crisper, but the torque steer is what seems better controlled. It's worth every penny.
L
Chicago
Thread Starter #14
Had my car up on a lift for the first time a couple days ago.
Turns out I've already got a Cobb RMM installed (bought my car used.)
I've never dealt with real torque steer or scrabbling.
All good to know, thanks!
Germantown
For me, lubricating with silicone lubricant and tightening the bolts of the passenger side motor mount made the clunks go away.
The last reply in this thread was from nearly 1.5 years ago. But the description from Larcat sounds like the clack that a lot of folks have noticed. There's just a lot of slack in the drivetrain. Some have quieted the noise with trans fluid replacement, some with axle replacement. If you have both wheels off the ground, engine off, trans in-gear, and you move the wheels back in forth, that sound of the gears hitting is a quieter version of the same clack sound that you get on the 1 to 2 engagement, as you load the trans on clutch release. 2nd gear engagement is typically much harsher than other gears because the ratio jump is much more significant. (harder to rev-match)
