Perfect Circle Autosport has brought in from the UK a small sample of wheels in sizes not commonly in use. These 17.5 and 17x8 fit stock size tires for an easy swap. The 18x8's will obviously need new tires, 215/35/18 suggested. On stock, mildly dropped, or on coilovers, all of these wheels fit.
Here is the sample inventory available right now. (Note the 17x7.5 is the same spec wheel as the COBB Fiesta.)
Pro Race 1.2, 17x7.5/4x108; Stock weight 18.1lbs each.
Low pressure cast, heat treated, and shot peened. Manufactured in the UK.
+Availability:
>Anthracite: 1 set 17x7.5/4x108/38mm offset w/63.4 hub bore
>Anthracite: 1 set 17x7.5/4x018/45mm offset w/63.4 hub bore
Pro Race 1.2, 17x8/4x108; Stock weight 19.8lbs each.
+Availability:
>Bronze 1 set 17x8/4x108/38mm offset w/63.4 hub bore
Pro Race 1.2, 18x8/4x108; Stock weight 19.8lbs each.
+Availability:
>Anthracite Spec 390 (no lettering): 1 set 18x8/4x108/42mm offset w/63.4 hub bore
>Bronze Spec 390 (no lettering): 1 set 18x8/4x108/42mm offset w/63.4 hub bore
Anthracite:
Bronze:
For pricing, please see this thread.
+Availability:
+Availability:
+Availability:
Anthracite:
Bronze:
