Motor trend says they got 0-60 in 6.4 seconds stock off the show room floor, and ran the quarter mile in 14.9 seconds @ 93 MPH. Mountune says they got 6.9 0-60 MPH quarter mile time from the two door version Fiesta ST. which is heavier than the four door US version Fiesta ST rocket. They also did a Dynamiter reading as well power at the wheels read 184 HP. @5200 rpm & 221 Ft. Lb.'s torque @ 2700 rpm's. The torque is more than Ford is advertising at the flywheel.
Here's the scup on that HP number that they arrived at' the 184 HP number is actually when the over boost is kicked off automatically after 20 seconds and when it's on for 20 seconds the system goes into over boost which is 21 psi and 197 HP mode. Some dynamiter charts shows both, and it will be mentioned like this 184/197 on the chart it will look like this two HP and Two Torque lines on one chart. Motor trend testing of automobiles is near sea level not to hot or humid not even any wearied atmosphere pressures to artificially raise the HP & Torque numbers.
