2015 Fiesta ST 102,000 mile maintenance necessities
Ohio
I've never had a car that made me smile so much. It's the best car that I've ever owned, and I am an artifact. My car has Mountune slotted brake rotors, with stainless steel brake lines. I also have a Mountune stainless exhaust, a short-shifter, and a K&N high flow air filter. The suspension is still strong; the car runs and drives great.
I am really interested in knowing what the mechanical necessities are for this100,000 mile IMG_1074.jpeg vehicle. I really want to take this car for at least another hundred thousand. Suggestions or recommendations?
Sam4
West Chester, PA, USA
standard maintenance. minimal changes - may not be the time for a big turbo swap. But I've been way wrong before....
FiestaSTdude
Cary, NC
Make sure the timing belt gets done before 150k. Our engines are interference engines so if that fails you will need a new engine.
I’d recommend that you flush the coolant at 100k. Brakes/clutch as well if you’ve not done it already
O
Ohio
Thank you very much; I didn't realize that. Ages ago, I had a Fiat X1/9 and the valves dropped in to say hello to the pistons… Not a good thing. I appreciate your input. I'll make a point of doing all of these things.
O
Ohio
Thank you very much. I appreciate it.
felopr
JD
i must be lucky as f because my car jumped a tooth before and it was fine, i run it like that for 10k miles also because lazy
