2016 FiST stumbles then dies
White Rock
On the way home from work tonight suddenly car dies at stop light. Wont idle, just dies, seems to run fine while driving around but dies at idle. Throwing code P0011 intake cam position timing over advanced (bank 1) and P0016 crank position correlation (bank 1 sensor A). Where do I need to start looking for what is causing this issue?
The vehicles timing needs to be checked...These are interference engines and if the timing jumps too much it will Hurt the engine....EXAMPLE Smash the valves with the pistons. Id make an APPT With the nearest dealer if its still under 5yr./60k mileage for powertrain warranty.
Portland
Also it may help to understand your modification level, and if any work was done recently or in the not so distant past.
