Drag racing rules can be pretty different that road racing and even autocross rules so one must study the standards of the organization they plan to participate with.
Taken from a road race perspective and understanding of most all if not all sanctioning body rules, some differences do show up. I have read all the rules and built my own roll cages, sometimes difficult to design to fit every set of rules.
I take safely very seriously but also know and take calculated risks but sometimes just have to accept it as it is.
1) No roll bar. Most do not allow any harness but stock but I have seen cars on track with a harness bar and race harnesses but that should not be mixed with reclining seats and usually not allowed. Reclining seats are designed to break towards the rear under the right load to protect you, a harness or roll bar there might do the opposite.
2) A proper roll bar, or cage. 4 point being minimum, DOM tubing, harness bar, diagonal bar, required, 5 or 6 point harness is usually required with actual race seats) (there may be an exception with some sanctioning bodies, and some may allow stock or reclining aftermarket seats, not a good idea usually unless you make a part to hold up the seat back in a heavy crash)
3) Track day events. Stock harnesses allowed nearly always with no roll bar. Roll over protection is required for most soft top cars but sometimes not, I had a very fast Vette modded for such use but no proper roll bar was available and making my own would of required massive chopping up the car to make a real one. I would not track that car without it so I sadly parted it out and traded towards something I could use, a new dually to tow my trailer.
4)Nice option if allowed for stock and race seats or reclining aftermarket seats which some think are race seats but they are not. I really like the Schrotch 4 point DOT approved harness, it has a section on one shoulder strap that comes apart to make it longer, twisting your body slightly and preventing sliding under in a frontal but lets you slide under in a roll over without a roll bar.
I had two "quick fit E36" BMW ones but could not use them for HPDE and TT events in NASA due to being labeled for E36 BMW even though it was easy to make them fit the ST....I sold them and now looking for another option as with hauling two big dogs in our car I do not want a roll bar in it. I have looked into making one that is pretty easy to remove, it would be bolted to welded in real gussets if I do so.
I could leave the Schroths in the car and use the stock ones for running errands or I could remove them in a couple of minutes, a very nice solution to safety and convenience.
NOTE: For some really odd reason there are bolt in roll bars allowed on track that simply bolt in to sheet metal and can be more dangerous than not having it. I really do not understand this as road racing rules are generally the highest standard ones there are.
Be careful of any bolt in bar or cage, make sure it really will protect you.
NOTE 2: Modern cars have very solid roll over structures built in, less so than some with sunroofs, far better than older cars ever have. I have seem some pretty serious roll overs with the roofs not flattened much but I have seen some that were fatal as well. I am taking a chance on my sunroof car when tracking it the way it is, stock, as we all are just daily driving a tiny car as well but at least it is nimble and gives us a chance, most of the time, to avoid most anything if we pay attention.
NOTE 3: IF you have a roll bar, cage, etc, you must pad it very very well if you ever drive without a helmet especially so. There is a dual density pad I used on the one caged car I ever street drove and the bar was far above my head and to the rear as far as I could go and I used either my race harnesses or Schroth for longer drives. We can stretch and move around inside the cabin far more than it seems in the right type of accident and striking a roll bar can and has been fatal or just brain dead results.
Any questions, recommendations, corrections, post away, the rules are easy enough to look up but I will help if needed
Rick
