5mm spacers
Bay Area
Anybody else running these? Was back and forth on mod plans finally decided at least near term no aftermarket wheels. Stock wheels are crying out for spacers. Could probably go 10mm for very near flush but will have liner and possibly lip contact and what effect on torque steer?
From a thread on here member stated that studs in H&R kit were same length as stock so went with ebay ones no studs and half the $$: https://www.ebay.com/itm/192273466766. Probably China sourced but decent quality, raw aluminum or at most clear anodized, think the H&R ones are grey hard anodized.
Will probably want studs or extended thread nuts, 7 turns at rear, only 6 at front, 8 is safe minimum. Only 2 threads short, can probably make ET nuts work with light reaming of bolt holes or may have identified a Dorman stud part number that will work, ARPs are overkill. I've been getting away with it, rechecking torque every couple days, living on the edge.
How much difference can 10mm (5+5) make?
Appearance change is subtle but slightly more aggressive. Torque steer may actually be lessened, at very least not worse. May even rotate better, only installed for a couple days but seems like it gets crossed up more easily lately. Only downside aside from lug length is you lose hub centering, no way to make a 5mm spacer with extended spigot, but I've had it up to 100 mph with no apparent vibration so looks like non issue.
flbchbm
Sterling, VA, USA
Edited.....I'm running 5mm with stock bolts. You get 6 or 7 turns, vice 8 or 9. My wheels are 6.5" narrow w/49mm offset Contour SVT's.
I'm running 5mm eBay spacers but using extended studs from the 10mm H&R kit. Had them over 120mph, no issues.
G
Bay Area
Didn't happen to try both 5 and 10mm? These work so well I'm trying to resist more is better.
Mikey456
I’m running the 5.mm spacers in just the back. When I lowered the car the rear wheels tucked in too much IMO. It’s not flush but it looks better. It also increased the trak and the car does not 3 wheel as easily.
2017 Ford Fiesta ST, Shadow Black, Recaro seats, Mountune RMM, Swift springs, 5mm rear spacers, Falken 615+ tires
Greenville, SC, USA
I run 25mm front and 20mm rear to clear my BBK. Also on whiteline springs. Don’t stack spacers, buy quality and use extended studs.
Mikey456
Those wheels look great on your black car. What brand/size are those?
CarGuy
Daytona Beach, FL, USA
They look like SVT Focus EAP wheels. EAP is European Appearance Package.
rallytaff
I have 15mm H & R spacers on my car with extended studs on H & R coil overs (lowered). Stock size BRAID wheels with no rubbing at all.
G
Bay Area
Thread Starter #14
Extended thread nuts FTW: https://www.ebay.com/itm/123236863846
Factory wheel bolt holes measure 0.620. A bit of internet research found these, lowest price on ebay, ~ $18 shipped. Pics look good, engineering drawing shows OD of shank at 0.612, at this price point definitely Chinese manufactured but worth a try. Parts arrive, surface finish and plating look good, shank diameters measure 0.612 - 0.615, should be min. 0.005 clearance, cutting it kinda close. Install with zero issues, no clearancing required, now 10 turns up front 11 at rear.
Verdict: anyone running spacers without longer studs needs these, at < $20 no excuse. Should work for any aftermarket wheel as well, just need to verify bolt hole diameter.
flbchbm
Sterling, VA, USA
Okay, sounds good; however, the true test is after summer to winter back to summer changes plus rotations. How well will the threads hold up after that. That's what I would like to know.
G
Bay Area
Thread Starter #16
Material is specced as forged Chromoly, threads should be fine, how well plating holds up is more my concern.
G
Bay Area
Thread Starter #17
Update: concern warranted, after maybe half dozen wheel installs plating on the cheap eBay nuts is starting to flake. Nuts themselves are fine, chrome just isn't holding up. Anyone doing this needs to try another vendor.
