This issue does not seem to be severe, but I would like to fix it.
Both rear brakes drag, the driver side has a heavier contact spot where you can hear a scrape / chuffing sound of pad on rotor once per rotation.
The passenger side is a steady light grinding sound.
Both sides spin "freely", and it isn't grabbing the rotor like a brake that is "stuck" in the normal sense of the word.
But, it's still not normal.
So far I have cleaned off the slider pins and placed a fresh batch of silicon grease on all the rear pins.
I also ground off the sides of the brake pads that make contact with the caliper itself.
I only shaved off a tiny bit, as the inner ones seem to not budge (on either side).
When I first took off the calipers, I needed to wiggle both inner pads free.
This worked for one evening, then the sound was back (but half as intense).
The brake rotors are the original ones, and all 4 have lips on the edges of the rotors, and are discolored with a burnt metallic blue.
I don't suspect the brake lines, mostly because the wheels are spinning with little resistance.
Is this issue due to the rotors only? or is there another problem in her that I need to address?
