Any experienced No Key Detected message?
MKVIIST
I went out to start the Fiesta today and saw a message on the navigation screen stating there are no key detected. Tried replacing the battery without any success.
MKVIIST
MKVIIST
Got it to start once, but it's still not detecting the key. I called roadside and they said the key may require reprogramming. Will have it towed to the dealer Monday.
airjor13
Centreville
Man that's sucks, hope they fix it!
Charlotte
Did you have to jump the car or possibly have it on (not running, but accessories on) for an extended period of time that could have drained the car battery? I know on some other makes (range rover for example) when the voltage is too low for the car to start the key has to be added back before the car will start. Keeping with the range rover example, on those, when you jump start them, you have to hold the fob against the steering column (the position is indicated by 3 protrusions in the plastic on the bottom of the steering column) and then push the button to start.. Maybe on our cars you could try holding it against the flat part on the side of the steering column (round area where a regular fiesta would have a key cylinder and where you hold it when setting up the mykey stuff) and pushing the button? Not a sure fire fix, but would definitely be worth trying if you havent already.
MKVIIST
MKVIIST
Did you try syncing the key through the menu settings?
I can't get the car to turn on ignition since it doesn't recognize my key lol
Colin1337
Kirtland AFB
I know its stupid. But have you tried placing the key near the sensor (which I would assume is in the steering column?)
MKVIIST
MKVIIST
Yeah I positioned the key all over the dash including the steering column and it didn't work.
MKVIIST
MKVIIST
Just received word from the dealer today that they'll need to order an ignition system because the remote receiver is bad.
