Installed my ATP MAP adapter/vacuum block in about 5 minutes, but here is a short how-to for those wondering how it goes in.
Tools:
T-30 Torx
8 mm socket and ratchet
Remove the engine cover
Right on top of the intake manifold on the timing belt side of the engine is the MAP sensor.
Remove the T-30 Torx bolt and pull the sensor up and out of the manifold.
The MAP block comes with a new longer bolt because of the thickness of the block.
Insert the vacuum block where the MAP sensor used to be. I had to turn the nipple 180 degrees because it pointed right at the engine cover post.
Once the block is on, put the MAP sensor on top of the block and bolt it down with the new 8mm hex head bolt. DO NOT OVER TIGHTEN IT! The intake manifold is plastic and can crack. Then attach your vacuum hose.
The cover will not attach to the post by the vacuum block. It rests on it. Time will tell if vibrations cause it to wear in to the under side of the cover. There is some sound proofing foam on the under side that might help.
Enjoy your new boost gauge (or BOV)!
https://vimeo.com/121738052
Tools:
T-30 Torx
