Officially available now!
*For USDM [MAP Tuned] Spec Vehicles*
No aftermarket tuning required. Will work on stock tune or aftermarket tunes.
This high performance VTA (vent to atmosphere) blow-off valve is precision machined out of aircraft grade billet aluminum. It features an all aluminum construction with a multiple o-ring and internal brass piston design that is pressure tested to withstand up to 70psi, allowing it to compliment even the most aggressive turbo builds. Spring pre-load determines the pressure differential required across the piston before the BOV opens and releases the pressurized intake charge. Designed to be a replacement for the OEM bypass valve and is available in 4 different colors.
Installation is simple and all mounting hardware is included.
Compatible with ONLY the Ford 2.3L EcoBoost OEM Turbo. For aftermarket turbo set-ups, please see our Universal Blow Off Valve
Available NOW on our website! : 2016+ Focus RS 2.3L EcoBoost Blow Off Valve - Boomba Racing, Inc.
Installation video!
[video=youtube;4mcTC75u6a0]https://www.youtube.com/watch?v=4mcTC75u6a0[/video]
And here we have the Boomba Racing ST Blow Off Valve resting in it natural habitat...
Comparison with OEM:
If you have any questions at all, feel free to let us know!
