BOOMBA RACING is proud to announce our new rear motor mount (RMM) for the Fiesta ST!
This direct bolt-on mount and bracket combine to replace the rear-lower engine torque mount, also known as a torque damper, significantly improving the vehicle’s traction and shifting response by reducing excessive engine flex. Wheel-hop during hard launches are also completely eliminated thanks to these mounts. Boomba Racing mounts are machined from high quality aircraft grade billet aluminum for strength, durability and looks. Inside each mount you’ll also find solid polyurethane bushings with the rigidity carefully chosen to optimize vehicle stability while also minimizing excessive vibration transfer from the motor to the body.
Installation is simple, does not require engine support and utilizes all OEM hardware. Mounts are available in Natural Aluminum finish as well as Red, Black & Blue anodized.
MSRP: $155.00
Boomba Racing Fiesta ST Rear Motor Mount - BoombaRacing.com
Water vibration Demonstration with Boomba Racing RMM installed!
0:19 - Engine Start
0:35 - Max A/C
0:56 - 1500 RPMs
1:00 - 2000 RPMs
1:05 - 3000 RPMs
[video=youtube;af6nhk0Tefs]http://youtu.be/af6nhk0Tefs[/video]
MSRP: $155.00
0:19 - Engine Start
0:35 - Max A/C
0:56 - 1500 RPMs
1:00 - 2000 RPMs
1:05 - 3000 RPMs
