Boomba Racing Sound Symposer Delete Kit Group Buy
We are excited to announce our complete Sound Symposer Delete Kit Group Buy for the 2014+ Fiesta ST!
GROUP BUY PRICING HAS ENDED!
Available for sale now!
Link for purchase: HERE
This direct bolt-on kit deletes and blocks the sound symposer from your 14+ Fiesta ST, cutting off the artificial drone noises being directed into the car's cabin, instead allowing you to hear your engine and exhaust tones as they should be. Included is this kit are an aluminum block-off plate and a delrin hose plug, both of which are precision CNC machined from high quality material with laser engraved Boomba logos. The block off plate features a threaded 1/4 NPT port and plug, allowing for allowing the end user to connect whatever aftermarket accessories they desire, such as our in-development catch can. This kit is also must-have for those higher horse power builds, where the increased boost levels could break the internal diaphragm of the OEM symposer components and cause boost leaks. Installation is simple and as well as completely reversible. The block-off plates are available in Natural aluminum as well as black, red or blue anodized.
This is the quickest and easiest way to delete your symposer without having to remove the battery and ECU connections.
Price distribution is as follows:
If there are 20+ participants there will be a 10% discount
Our kit is available immediately and as soon as the group buy is met, we will ship!
These are offered in our traditional colors of Natural, Black, Red, and Blue anodizing.
We will be giving participants a special coupon code for purchase.
1. westcoaST
2. _Hunter702
3. Tex ST-AR
4. wwuchris
5. Fitty
6. BrokenSVT
7. scooby2
8. miketank89
9. Cantinmeatless
10. toptier
11. joshrhyno
12. cobrat - not on this forum
13. STenthusiast
14. ednutcracker
15. ClimbITerp
16. wspec
17. VAFiST
18. TapTapPull
19. FiestastQc
20. WScottCross
21. soldjeepforst
22. jfdana
Sign me up I haven't decided if I'm going with black or red yet I leaning towards red.
When you place your order you'll be able to make your final decision on color! We'll get you added!
westcoaST
Corona
Having actually pulled the hose from the symposer to install the mountune charge hoses, you have to loosen the hose clamp, then break the hose loose from the symposer. Sometimes this requires sticking a few flathead screwdrivers in between the hose and the symposer, Then install the blanking plug. I use silicone lube to aid in installation. Then you need to pull the other end out of the firewall, then install the Delrin plug. May need to pull the battery and battery box. By my watch, a little more than 5 minutes.
JPGC
Middleburg
I think the delrin plug just plugs the hose that leads to the firewall. You can't just disconnect our hose from the firewall as it goes all the way through and ends in the center of the car behind the dash.
mrtn
With a little more info on the pros and cons of this as well as info on the install Id be in. Might want to add on the short shifter and base bushings if I'm paying for shipping anyway...[emoji39]
