Boost Operated Blow Off Valve - Boomba Racing
Available now: http://www.boombaracing.com/2014-fiesta-st-boost-operated-blow-off-valve/
Boomba Racing is proud to announce our Boost Operated Blow Off Valve for the 2014+ Fiesta ST.
This kit will replace your weak and leaky OEM bypass valve in favor of something much more up to the job. The Boomba Racing Boost Operated Blow Off Valve comes with everything you need to install on your vehicle for a true plug and play installation. It features 100% vent to atmosphere operation and billet aluminum construction with a brass piston to ensure leak-free operation for years to come.
The Boomba Blow Off Valve uses an ECU controlled solenoid that provides the blow off valve with both vacuum and boost pressure. Using boost to close the valve keeps it sealed no matter what the boost pressure is. The higher the amount of pressure, the stronger force there is keeping the valve closed. Vacuum is used to keep the valve open in this configuration. This with the combination of the ECU controlled solenoid prevents the valve from any fluttering or premature opening. This also works to eliminate any unwanted pressure spikes during venting. The purpose of this blow off valve is to prevent turbo lag and allow the car to hold boost in a steadier manner. When the throttle plate closes, excess boost pressure is vented so that the turbo can continue to spin during higher RPMs rather than surge from backpressure. The blow off valve is tested to over 75 PSI to ensure leak-free operation. The electrical connection on the provided solenoid matches right up with your factory wiring and there is no need to splice or trick your ECU with resistors.
Don?t hesitate; pick up lost power by replacing your factory BPV with a Boomba BOV, today!
As always this product is designed and manufactured 100% in-house in the USA.
Available in your choice of color: Onyx Black, Royal Blue, Race Red, or Pure Aluminum
Installation video
[video=youtube;Y-QB7R_HuWQ]https://www.youtube.com/watch?v=Y-QB7R_HuWQ[/video]
[video=youtube;LLOVKzv1-t4]https://www.youtube.com/watch?v=LLOVKzv1-t4[/video]
[video=youtube;uk7EdtD9Ycg]https://www.youtube.com/watch?v=uk7EdtD9Ycg[/video]
Long Island
Nice product. Why is the fiesta blowing black smoke from the tailpipe when it turns out of the parking lot??
Easton
Is a block off needed for the factory one? Thinking, if the factory one leaks this much, just unplugging it will not work.
Sorry, I get it now! Replaces stock one in factory location.
Sent from my VS985 4G using Tapatalk
Fort Carson
I think the video made it worse sounding than it is with the editing...on the flybys, it was just "vroom-pshhh, vroom-pshhh" back to back with nothing to break it up. Definitely loud though. I'm new to turbo cars, so is this something (BOV's in general) that aren't as loud when driving normal, with say 2k-rpm shifts, or are they always the same volume I guess regardless of if you drive like a granny or a 16-year old?
Sekred
Mid North Coast
What is the advantage of using a 3 port solenoid rather than hooking straight to the intake manifold to pick up the boost/vacuum?.
As far as the leak test goes, the OEM BV needs to be powered up to close (and seal).
GAbOS
Carson City
This
Also, it's loud as fuq.
Thread Starter #15
Price will be $235 for the entire kit.
Car is running a Cobb OTS tune and is a little rich, that was just unburnt fuel exiting the tail pipe.
Any chance for an non-vented to atmosphere ?
We hadn't planned on it but I can bring the idea to my engineers.
What will the cost be on this, and is it quieter then the BOV Adapter?
It is $235 and since it is 100% vent to atmosphere, it is just as loud as our BOV adapter. Maybe slightly quieter.
No block off needed as it installs in stock location!
Thread Starter #16
The three port solenoid will allow the valve to be fully controlled and regulated. This means it will only stay open when it needs to, and it will always stay fully closed and not leak when it needs to. Also, by utilizing a plug and play electronic connector, our unit does not require any splicing to trick the ECU with false signals.
Also new to this game, especially the stock setup, as I don't even have a car to look at right now. :(
This will absolutely need to be changed to a 'real', aftermarket, charge pipe mounted BOV once upgrading to a big, aftermarket turbo setup (DHM kits, etc.) correct?
Will it still work with the ever popular on here 'Cyborgs'?? (Like I said NEWBIE to this game. ;) )
Thread Starter #18
Some aftermarket turbos still utilize the stock location, others force you to relocate to somewhere like charge pipes.
Gloucester, VA
Got the shipping info on mine today. Yeah I'm an old guy but still a kid at heart. The FiST is simply a toy so I can have fun and play with the kids... LOL
Thread Starter #20
The install video will be up in the next day or two!
