car holding rpm at 1500 when shifting into neutral
Niwot
Today I shifted into neutral when coming up to a stop sign, the revs dropped but then stopped at 1500 rpm and sat there for a few seconds, then continued down. This now happens every time I shift into neutral. The car is stock, with 42,000 miles. Anyone know what this issue is?
ColoradoST
Niwot
Thread Starter #2
I should also add that I am at 7500 feet elevation (2500 feet more than the car is "used" to).
Easton
When up shifting, the ecu will set the revs for the next gear. If you are shifting down from any gear other than 6th, it will hang for a few seconds to sync with the next higher gear. If no higher gear is selected, it will drop to idle.
Sent from my VS985 4G using Tapatalk
ColoradoST
Niwot
Why did I just notice this now? Normally when I shift into neutral, or press the clutch in it will instantly drop to around 1000 rpm.
ColoradoST
Niwot
More info : I am driving at around 4000 rpm and shift to neutral, the rpms don't lower for about 5 seconds then procced to lowering very slowly.
ColoradoST
Niwot
Car seems to be running better, at a lower elevation.
Roseville
It's normal, mine does it too, and its bone stock. Kinda trippy though when you come from the world of low tech manual cars.
Zissou
Charlottesville
I geeked out the day I figured that out. Spent most of the drive playing around with up shifting and seeing how long it holds rpm.
