I went to get into my FiST and found my clutch pedal stuck the ground. I gently lifted it up with my hand and drove it about 10 miles and everything felt normal.
I have been reading about horror stories about the slave cylinder and the transmission needing to be dropped.
Not sure if I should continue to drive the car or have a shop tear into it immediately. The heat index has been over 100 degree the past couple of days, I am not sure if that could have anything to do with it.
Car was just serviced and I had the brake fluid replaced. Drove the car over 300 miles afterwards and everything seemed fine until I got in the car a week later and found the pedal on the ground.
My car is a 2015 with a little over 40k miles so I am outside warranty.
