Hello guys and gals,
My Fist has 5k miles and occasionally when I'm coming to a stop the idle drops significantly and stumbles a bit, but only when i come to a complete stop and just for a second or two. Doesn't feel horrible but I can surely see the needle go below appropriate levels and jump back up to normal quickly, car idles fine afterwords until I get up to speed and decelerate to zero again, does it every maybe 15 stops.
No CEL
only aftermarket is cobb cutback exhaust.
Ford did however overfill my oil significantly on the first oil change. I counted exactly 5.1 quarts that came out of the drain pan, called them and they said they billed 5 quarts. However our vehicles only take 4.3 quarts.
Ive attached a picture of how full the oil was, I checked it about a week after they changed it and discovered then it was overfilled, in that time I put roughly 150-200 miles on the car before I decided to check it and then discovered its overfill point.
the end of the red straw indicates the point at which it was overfilled to.
Thanks for any information, I am wondering if the overfill has to do with this strange idle drop issue.
No CEL
