So I've been getting this code intermittently. Is there a way to check with forscan what's causing this code? The code is a p0480. Intermittent failures are things that can't fail more than once so.... I can rule out fuse or relay right? This thing has 2 relays I think, 1 when temp reaching 210 and then one when ac clutch is on, or is that a switch? I've got a mountune radiator, 160 degree thermostat and running yellow coolant.
