I wanted to share this in case anyone was interested in my little experiment.
Long story short, as part of preparing for a backpacking excursion, I have come up with a way to get stiffer springs with stock ride height, using stock struts, or hopefully any stock-height replacement struts (I have put them on Bilstein B6 Struts in the front - car is currently still rocking stock rears). Here's a picture post-dirt bath:
If you want to read the long version with all the nitty gritty details on the assembly, its in my build post here if you scroll to page 2
https://www.fiestastforum.com/threads/feisty-the-family-car.30825/
Essentially, I have come up with a way to make a budget DIY ~$350 spring setup (before shipping) using 225F/200R rates that turned out to sit pretty close to stock ride height. I was shooting for 0.25-0.5" of lift, but ended up with no lift at all. You get what you get! The setup uses standard 2.5” ID Coilover springs in the rear, and standard 3.0” ID coilover springs in the rear - a less ubiquitous size, but reasonably common in large body offroad truck shocks, ala Fox.
Parts List! (Edited with more options and links)
Here is a "budget" parts list I put together if you want to buy everything brand new as but as cheaply as possible. Note, the 225lb front springs I used were on clearance, so if you can’t find them cheaply, there are also some options in 200 and 250lb that can be had more affordably from Landrum (who mostly makes stuff for OEMs) and other companies. I also stumbled across Magnitude performance, which looks remarkably affordable, and is apparently made in Texas. I also updated the parts list, as "Viper Springs" has some very affordable options (No idea where they are made). Seemingly a decent alternatives to cheap questionable ebay stuff.
Links:
Springs: (need to select correct rate and choice of color for the two different ID springs)
Viper 3.0x10 225lb front (Need 2x): https://f-o-a.com/shop/viper-3-0-inch-id-spring-10-inch-length/
Viper 2.5x10 200lb rear (Need 2x): https://f-o-a.com/shop/viper-2-5-inch-id-spring-10-inch-length/
Front Bits:
3" Camlock Rubber Gaskets (Spacer need 1x 5-pack): https://www.amazon.com/gp/product/B0B3W8BXYD/
Thrust Bearing 80x105x4mm (Spacer, need 2x): https://www.amazon.com/gp/product/B0B5XR9W14/
Mookeh 2.5" Helper Springs (1x sold as a pair - get the shorter 3" tall ones): https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=mookeeh+2.5"+helper+spring
(Pretty much any zero rate 2.5” ID helper will work, these are just the cheapest I’ve found)
Note, because this is sort of an experimental setup for me while I'm working on a more long term solution, I did it on the super cheap. I used the SSS front springs and parts listed in the front (off Ebay and Amazon because I was in a hurry), but in the rear I scored a set of pair of off-brand 200lb coilover springs off ebay for $50 shipped. So who knows how well they are matched and how long they will last before sagging. I used a set of helpers I had already that have a 0.5" stack height instead of the 0.7" for the "Mookeeh" ones (which are a brand I've never heard of off ebay)
Obviously, you can substitute higher quality components, but expect to pay significantly more for them. But for a set of "Rally Springs", the cheap ones are fine for now. One caveat with this setup is that the cheapass rubber camlock gaskets I used are 3" ID 1/4x1/4 rubber rings with a slight stretch (technically 10% is okay for rubber orings), and its questionable if they'll hold up or just split after a few weeks/months. Still on the lookout for something better that's 3.25" ID, between 1/4" and 3/8" thick and made of something a bit more robust. I was in kind of a hurry to get ready for the trip, so I went with what I could find. I can make a custom spacer ring easily, but that kind of defeats the point of the "anyone can do this" I was going for. A Poly spring isolator would be nice, but I haven't found one exactly the right size yet in the universal ones, and its hard to find details on the car model-specific ones out there.
I measured ride height by the service manual between control arm bolt heights, After walking out and measuring, I’m at 13mm/19mm (only measured the driver’s side in a hurry - logic says passenger side might be ever so slightly higher). My measurements are probably +/- 6mm or so
Stock ST is listed as 12mm/15mm and Base Fiesta is 16.5mm/40mm. Keep in mind the service manual also says +/- 14mm so there’s plenty of room to go even higher!
On that note, you can adjust the ride height up or down slightly (approx +/-8mm) by choosing a slightly stiffer or softer spring (I recommend staying between rates of 200-250 front and 175-225 rear). I would also not recommend going above 225/200 on the stock shocks. Bilstein B6’s might be good for 225/225 or 250/225. 250 may be a bit too much on stiffer street tires (you can run slightly stiffer springs with softer sidewall snow tires) but YMMV
Last caveat is this is obviously a thrown together DIY setup especially the workarounds I did in the front and I've done no long term testing, so anyone trying it should do so at their own risk!
Links:
Front Bits:
