Razorlab: Logic map might be boolian algebra equations relating sensor read variables to the parameter maps, like what my logs suggest, IF CAT exceeds 109F THEN timing is retarded in increments as CAT increases further. The order of all the ECU decisions with modifiers like if, AND, OR, greater than, less than, etc. Or maybe a hierarchy set of decision trees. There must be something like this in the hard code.
Stock tune starts pulling about 1.05* at 110F CAT. (-17.50x0.060 multiplier)
Cobb Stage 1 starts pulling about 1.50* at 110F CAT. (-25.00x0.060 multiplier)
At 100F it's 0*. Like most ECU's, I would imagine it interpolates between the 100F cell and the 110F cell if your CAT falls between that. Same with 110F and 150F cells.
Iso100: my logs show total timing advance as low as 8 degrees at high RPM. Ryst posted some stock pulls with 14 degrees advance same RPM. More later, local snook calling at 4 am.
Also, if the car is over 2.0 load or 5500 rpm it will no longer use that dynamic strategy. However, you can change that in ATR.
