FS Fourth of July Special $49.99 Dpro Rear Camber plates 2+ degrees nominal negative camber! ! for your FiST!
Trader history for Dpro (5)
JDG
Conshohocken, PA
#41
The issue that I had when adding camber plates is that the additional thickness of the rock Shields cause the ABS sensor not to protrude far enough to correctly read the cog on the hub.
Ohhh I see! That makes sense now. Do you have any issues with ABS as described above?
#42
In addition I removed my rock shields because I have larger brakes as well.
I have never had any issues with my brakes and my ABS works perfectly.
JDG
Conshohocken, PA
#43
OK, it looks like if I wanted to run the rock shields, I could cut out a rectangle the same shape as these plates and then weld it back on to the plate as to not increase the thickness more than just the plate.
#44
My question to that would be.
How would the rock shield be held in place?
JDG
Conshohocken, PA
#48
Now thats a novel idea! A little extra work.
After thinking it over with @D1JL and looking at photos of rally cars, I might just delete the rock guard like everyone else. Most rally cars don't run them and use a different method for deflecting rocks away from the wheel/brakes. It seems to cause more trouble due to rocks getting stuck between the rotor and guard with the OEM unit.
Thread Starter #49
This has actually become a consensus, I have noticed the same thing. For all intensive purposes rock guards are most likely a relic from earlier times. I think its like all the crazy things that manufacturers do to eliminate every single chance of possible NVH. There may not be any but they figured out it will help so they do it.
I point to the weights stuck on our stock struts as example.
Fort Bragg, NC, USA
#52
Thats an Idea I did install my Camber plates with the backing plate and my abs light did come on,
So basically its hit or miss on if someones will but I recommend not using the stock backing plate which is actually just a stone guard. It is not a dust shield lol.
anyways updated price people now $85 shipped 1.8 degrees negative camber with these plates installed.
Can you make any to have -2 degrees
Chino Hills
#58
On really tight back roads where I am located, it can be felt, I can also feel it doing its thing when I'm braking hard.
Sent from my moto g(6) using Tapatalk
