Drivers window doesnt roll up completely at first
West Bend
I noticed something strange with my drivers window yesterday. When I roll up the window it stop short of completely closing. If I pull the switch a second time, the window goes up a bit more and full closes (approximately 1/4 - 1/2 of an inch). The auto open on the window works fine, but I'm not sure if the window is supposed to be auto close also. If it is, mine isn't working because I have to hold the switch to close the window. All of the other windows are working fine and close fully the first time.
The car is a '16 with only a few hundred miles on it, so I don't know if this is normal. I'm guessing it's not. Does anyone have any insight as to what's going on?
Shelton
Workshop Manual
menu
501-11 Glass, Frames and Mechanisms2016 Fiesta
General ProceduresProcedure revision date: 11/11/2015
Power Door Window Initialization - Vehicles With: One-Touch Up and Down Driver Window/One-Touch Up and Down Front Windows
Initialization
WARNING: Before beginning any service procedure in this section, refer to Safety Warnings in section 100-00 General Information. Failure to follow this instruction may result in serious personal injury.
Refer to: Health and Safety Precautions (100-00 General Information, Description and Operation).
WARNING: Keep objects and body parts clear of the glass panel when carrying out the initialization procedure. During the initialization procedure, the glass panel closes with high force and cannot detect objects in its path. Failure to follow this instruction may result in serious personal injury.
NOTE: Make sure that the window runs are correctly installed and free of foreign material.
Start the engine.
Lift and hold the window control switch until the door window is fully closed.
Release the window control switch.
Lift and hold the window control switch again for at least one second.
Press and hold the window control switch until the door window is fully open.
Lift and hold the window control switch until the window is fully closed.
Test for correct window operation by carrying out the one-touch down and one-touch up features.
Page
Wrenching for Ford is what I do
J
West Bend
Workshop Manual
menu
Initialization
Start the engine.
Page
Thank you for the info! I'll give it a try when I get home.
ATL
Mine had the same issue. Had the dealer do a reset and the issue is fixed.
Louisville
Had the same issue with my '16.
Never thought to ask about it, but I'm glad jailbird did! Zombie's reset worked like a charm.
Thanks guys
