Eight Speakers???
Raleigh
Where are they? I think I've found 7, two in each front door, one in each rear door and one behind the touchscreen...Where is number eight? [scratch]
Bedford
Behind the touchscreen? That doesn't make any sense.
The rear speakers are coaxial speakers I believe. A woofer and tweeter built into one speaker. So they count that as 2. At least the tweeters are in the right place up front which is what matters.
Georgetown
Two drivers in each rear location. Two mid/woofers and separate(component) tweeters in the front doors. The vents behind the touch screen are just that; vents, to allow heat to escape from the sync setup.
konatodd
Raleigh
That would explain why I couldn't see a speaker cone behind the touchscreen...Thanks.
RAAMaudio
Carson City
Actually and unfortunately the tweeters are in a pretty bad location, A pillars aimed at each other would of been hugely better.
There are other locations that can work decently well but pillars are super easy from a manf perspective, problem is they seldom use or at least listen to audio engineers....
Just to explain my position on this. I have been an audio competitor in sound quality, beaten a world champion with two different systems, been an audio judge, published, own a sound deadening product line that has been used in several championship installs, etc.....it would of cost them practically nothing to put them in a better place:(
RAAMaudio
Carson City
That can work really well if properly executed which most installers do not understand the basics of and normally further forward. Many championship winning installs have mids and tweeters at the base of the pillars or in the general area but it takes considerable testing and then tuning to get it right, not many people in the world would know how to do it.
In many vehicles mids and tweets in the kick panels is the absolute best place with midbass in the doors if a three way setup is done.
7 page article and more pictures on this link, the truck was not even fully tuned when reviewed and not done in a proper location, it was significantly better than the reviewer had the chance to hear but it was a very tight schedule to get to print on time.
http://www.raamaudio.com/1996-toyota-tacoma
Unfortunately I did not have the time to finish the mini Recaro rear seats, molded kick panel and console covers, etc...there were 5 amps, the processors and subs and more storage and space inside than stock, it was a considerable project to say the least.
My absolute favorite get it done, simple, superb if not absolute best results(championships have been won with this method) is to put the tweeters in the pillars 1" above the highest point of the dash aimed right at each other though in some cases a slight adjustment up and toward the listeners no more than 10 degrees works better.
Wire the tweets out of phase which is just reversing the positive and negative leads to help time align the arrival to your ears with the mids in the doors.
Doors, deaden them decently, use the stock locations, pretty simple.
Using low weight speakers and carefully applied deadening results in a low added weight and huge improvement in audio and in the case of the FiST, pretty mind blowing:)
Of course you need some amp power, sub, and tuning for the absolute best but just using the stock and not so great HU it will still be far better.
The mag review was my Tacoma built in my back yard, outdoors close to the beach in La Jolla, $20k retail in gear but for less than 10% of that you can get incredible results:)
Rick
