Engine compartment air inlet
Lecco
https://ibb.co/ezYhBz
This is what I've done to improve the air inlet in the engine compartment.
I've deleted all those plastic parts which blocked the air entrance in the compartment.
The car radiator now takes lot of air, thanks to the A/C radiator removal.
Another pic better shows:
https://ibb.co/m35c49
anticon
Sherwood
It seems like the air is just going to go around the radiator now. I assumed the plastic and deflectors keep the air going through the radiator and not around it. It seems the removal of the A/C heat exchanger will open up the surface area to the radiator though so maybe it balances out?
Perfblue15
Canyon country
This honestly looks like it would hurt cooling more then it would help it. All the plastic shrouding in the front of the car is meant to funnel air into the factory heat exchangers. I would not be surprised of this caused more overheating issues with your vehicle.
TheSixtyFive
Lecco
What You said is right [:)]
However I can say that before my...lightening work, the engine heated up a lot, after I noticed an exponential improvement [:)] [:)]
cxwrench
Marin County
I wonder if Ford has any engineers that actually designed that ducting so it worked better than not having it?
Mikey456
I’m not sure what you are trying to accomplish with that setup. But I trimmed About 1 inch of rubber between the rain gutter and the engine compartment to vent some of the hot air out of the engine particularly in the turbo area. The rain gutter is still a quarter inch deep in that area, so unless it really pours rain The water should not enter the engine bay.
