Hello everyone, I’ve recently put a new trans cell in my car. (About 2 weeks ago) drove okay but I had the sticky clutch pedal issue, so today I got to installing the new clutch pedal assembly as some other threads suggested and after bleeding I put the battery and air box back in ( I let batter charge while doing the install) when getting back in the car I press the clutch down and went to turn my car on. Sync just kept saying “push clutch pedal down” can’t help but think I damaged the sensor wiring or maybe damaged my car battery (wonky charger). Cluster does the little flicker when I turn it on so maybe the battery is just dead. The sensors are pretty cheap but should I be looking if some wire pins fell out of the connector, or what’s the best corse of action.
Also replacing the pedal assembly seems to have worked for getting rid of that stupid sticky pedal.
