Focus mk2 2010 rs gearbox oil leak
MKIIIRS
Looks like its leaking from the CV joint, which is the black rubber piece. It's easier if you replace the entire axle.
lukefergusonc2
Rhondda Cynon taff
Sorry I don't now much about this why would u change the drive shaft is that what you mean when it it's the seal around the spine ?? Another thing I have noticed since this has started is when I slightly turn the steering wheel left whilst driving it making a groan/vibration noise any ideas I thought wheel bearing but not to sure Thanks for the help mate [emoji1360]
lukefergusonc2
Rhondda Cynon taff
I thought in the boot it ha grease not oil ?
Thanks everyone for the help hope to get it sorted because it's doing my heading!!!
LonestarRS
Georgetown
The grease becomes oil when it touches the hot engine. If it was leaking you'll have a puddle of oil where you park.
MKIIIRS
Most people just swap out the entire CV axle since it's not much more expensive than rebuilding it. Normally when the CV boots goes bad, the axle has been worn down enough that its best to rebuild or replace the entire thing.
There's a left and right CV axle (half shaft) that drives the front wheels. You can replace one side or both depending on your budget. The clicking noise that you are hearing is very typical of the CV joint going bad due to contamination or lost of grease.
lukefergusonc2
Rhondda Cynon taff
Cars under AA Gold extended warranty so I'll call them see if they will sort it out that's if they don't call it wear and tear like most warranty company's do I don't think there was any splits in the boot mind but when your sitting in passanger seat you can feel slight vibration in the foot well ?
lukefergusonc2
Rhondda Cynon taff
Hello guys fixed the leak it was the driveshaft oil seal leaking just got a hummin/vibration noise while driving and turning the steering wheel slightly left
lukefergusonc2
Rhondda Cynon taff
Thread Starter #15
Just the seal on the gearbox checked shaft can't see any boot leaks or hear no clicking any other way of checking?
lukefergusonc2
Rhondda Cynon taff
Thread Starter #17
It's all dry sounds like a wheel bearing But the sound don't go whilst taking weight off either wheels [emoji848]
