Ford Sync 4?
Michigan
So after a couple days on the job Sync 4 won't work on the fiesta, the software is drastically different and the test benches we use are very different from sync 3 benches. Also sync is very platform dependent it's not like a normal desktop program or web page where it can adapt to different display sizes, each display that Ford uses is programmed with a specific version of sync for not only the screen size but also the ac controls, steering wheel controls ect. If I am wrong I'll update this post but from what I know now it doesn't look likely that sync 4 will work with our hardware.
Right now I will actually be working on the final version of Sync 3 before switching to Sync 4 so I may eventually be the guy on here to talk to for Sync 3 issues or questions.
Ventura, CA, USA
Have you guys seen the "refresh" or Sync 3? I guess it's a refresh or face lift? I've noticed it in several 2020 Ford Products.... Is there anyway to do a flash update to make our Sync 3 have the refreshed layout like this 2020 Mustang has in it? Go to 2:37 on the video to fully see it.
View: https://youtu.be/DqJOss1LoVI?t=157
Michigan
You might be able to configure that with Forscan, but it might be a specific theme for the mustang that may not be documented yet. Here is a little documentation on the other themes you can set with Forscan. https://forscan.org/forum/viewtopic.php?t=6676
Macomb, MI, USA
You can check if the theme exists with test settings on the radio.
Hold Eject and Seek Next. In test settings there is a theme dropdown, but it only sticks until next reboot
