FORScan reverse/backup camera discussion thread
brbauer2
St. Charles
Ok so I was able to add a backup camera without issue but now my center console USB ports are not providing power so my Dashcam and Android Auto no longer work. Anyone know if this is just a Sync issue or an actual APIM programming issue? The only number I changed was the one pointed out and I tried both 2 and 3, both worked fine but still no center console. Should I restore factory and see if the USB works then or has anyone seen this problem before?
Only thing I can think is you didn't plug everything back in on the back of the module or you somehow plugged the USB data cable into the wrong spot (there's two USB in ports on the APIM unit).
Ironton
Now that I think about it, I believe I overlooked plugging the mini-usb plug back in, .. of course! I'll have to fix that tomorrow thanks for the reminder lol
Houston
Just an update, I've got a 2014 ST. I installed the backup camera, everything is working. Pins 14 and 15 already had wires in them. I removed those pins from the harness to put my camera in so it seems like my car had some of the harness installed for the camera. No clue where those wires went though.
iso100
What values did you use in FORscan?
Sent from my LG-H931 using Tapatalk
CarGuy
Daytona Beach, FL, USA
Maybe your car had the wiring already installed. Did you check the hatch area for extra wires?
Houston
http://www.fiestastforum.com/forum/threads/16439-ForScan-and-how-it-can-help-fiesta-focus-owners
I didn't really check because I had already installed everything by the time I got to the Sync part.
Innisfil
Hi gents, new to the forum and I am having an issue with the backup camera I just installed on my 2017. When I shift into reverse, I get the blue screen with "check your surroundings" at the top and a small + button in the top left but no image from the camera. After a few seconds screen goes black and then exits back to sync screen. Then a pop up message appears "camera is not available". Now, I have run the wires direct to the #14 and 15 pins. I have power to the camera, I am getting a 3 volt signal at the pins when the car is in reverse and 0 volts when not in reverse. Tried multiple APIM changes as suggested in previous posts. Can anyone shed some light into what my issue could be. I have been searching for days and I have tried everything.
Nicholasville
As I understand it, and please correct me if Im wrong, if you are getting that screen with the + then you have the right apim changes. If you are getting a camera not available then you either don't have power to the camera or the camera is bad.
Innisfil
I am getting power to the camera. Camera is wired to the reverse lights. When I check voltage on the number 14 pin on the with the car in reverse i get over three volts. When I take it out of reverse it drops to 0. That tells me the camera is turning on and is producing at the very least a signal.
Mount Dora
Have you tried swapping the two pins? I know I had a similar issue and swapping the two fixed it
Innisfil
Yep.... tried swapping the pins because one post said Pin 14 was the male of the RCA and pin 15 was the outer. Another post stated the reverse. The wiring diagram I found states 14 as "rear view camera signal" and 15 says "rear view camera return" so I believe pin 14 should be the male.
VuDoo
Dallas
Thread Starter #252
Sounds like a faulty camera. If you are getting messages check your surroundings then it is not a FORscan issue. If you have switched wires around and nothing works. Must be your camera. I will note, that getting a blue screen when shifting in reverse is not normal. It should just be just a black screen. Sounds like something is up with the camera itself.
Innisfil
Thanks for the quick replies everyone. I am going to run an extension off the rca from the camera and plug it into a small tv to see if it produces anything. Then I guess I will know for sure where the problem is.
Innisfil
Looks like the camera is working...........Now back to Forscan.
Can anyone give me the apim they used on a 2017 Fiesta ST with sync 3?
I think I can safely say I have narrowed it down.
And please don't laugh at my cheap garage TV....yes it's a SOYO lol
Nicholasville
What I used on my 17:
7D0-01-01: 2330 6105 C052
I did have to do it twice. I don't know what I failed to do the first time but it took a second pass at writing the config before it worked for me.
Dearborn
Does that TV show you the format of the signal?
I wonder if the problem is that your camera is putting out PAL/576 line - I think our cars need an NTSC/480 line signal.
Dearborn
If it is capable of both PAL and NTSC then there must be a switch or some way of changing the output from one to the other. Maybe the manual says how to do that?
