So I noticed my car making a grinding noise of sorts from the front end. It definitely sounds rotational, like gears not meshing, or like something is rolling around in the transmission, but its not crazy loud (have to have everything turned off to hear it). That being said, I put the car up on jacks and put the car in gear and I can't really hear it. I am running motul gear 300 in the transmission (changed it since the noise started and no real change). The noise continues even with the clutch in, or in neutral if the car is rolling. I also only really hear the noise at low speeds, don't hear it much past about 25-30. Any ideas? I am thinking maybe drive shafts or drive shaft bearings? Any advice or things to check are appreciated!
