Hello, Im Andrew. I have a 2016 ST (58k miles) with an s280 turbo, HPFP upgrade and injectors, FBO, and I’ve been having a misfire issue under WOT for months. I have tried getting new coil packs (NGK, one failed recently after being used for maybe 3k miles), I’ve gotten my intake valves and throttle body cleaned, compression is good, gas is good, all temps are good. I have step colder iridium plugs (less than 3k miles on them), I’ve tried .028 (undrivable, misfires in every gear at any boost), .026 (only misfires in 4-5-6), .025 (4-5-6), .024 (4-5-6), .022 (more misfires than .026, but still 4-5-6), .019 (about the same as .022). Car seemed to misfire much less after getting my valves and TB cleaned, and I should also mention the misfire seems to get worse after the engine gets warmer. Dizzy tuning can’t see the issue on their end, and my mechanic wasn’t able to find the issue yet. If anyone has any advice for me that would be great, I don’t wanna spend any more money on fruitless diagnostic. Thank you!
