Yes, I stripped the threads in a bolt hole in the head. I lubricated the header bolt so it would spin in easier, and didn't adjust for that mentally when I was tightening the bolt.
Oh, and that's not all. I also must have overtightened the bolts on the downpipe and now I can't get a seal between the ATP turbo to downpipe adapter flange (the one with the large fire ring). Damn car sounds like a 4cy version of a top fuel dragster, but's only making 2psi of boost. LMAO!!! Luckily I have another car I can drive while I sort out this mess. I have another turbo arriving tomorrow, so that should fix the flange issue.
Update: I just thought of something. What if the uppermost stud on the DP flange (which isn't visible under the car) backed out a little bit? Woudn't that prevent the flanges from seating flat against each other? I really hope the problem is that simple. It's hard to believe I could bend those thick flanges with those tiny studs.
