So when i left this evening the car offered a new noise, guessing it's a boost leak but i figured i'd ask here first. The problem, once i get past about 15 psi, it will make a vibration and sound and loses power. The sound is like a loud fluttering, a very fast thud thud thud thud, almost like an old car with bad exhaust leak, similar to when it was constantly misfiring on #2 due to a bad plug connection. But this only happens once i get past about 15psi. In all other circumstances it sounds and drives exactly as it should. For reference it has been running as high as 27psi with no issue until this today. Charge temps are as they have been for months so i assume the FMIC itself is operating normally, it would seem there's a threshold of about 15psi where everything is normal till then, then it's spuddering. If i continue to WOT during fluttering it hasn't gone past 22psi, although i haven't been too pushy just in case it was something else wrong.
Looking up boost leaks i read a lot about hissing sounds and such but considering it seems to have that same 15/16psi threshold before it gurgles, i was hoping it was a hose clamp that's loose or something and was holding boost till that point. About a week ago i had a catless DP installed but that should be on the exhaust side and shouldn't affect boost right? No engine codes popped fyi. Taking it to the shop that has done all my work so far first thing in the morning but i wanted to ask here in case i had any advice/info to bring with me in the morning.
