Idle issue
Anybody experienced bouncing idle whilst coming to a stop it’s only does it for roughly 3 seconds then levels itself out ??
Plus the car has decat but noticed it’s running really lean/rich lately?
GhostRS
Moderator
Staff member
Ah lean/rich?
These are completely different things. Lean is dangerous, so if that’s the case I’d get that checked ASAP.
I believe an issue with your 02 sensor will trigger a check engine light
Not sure what you mean by "has decat"? Have you removed the catalytic converter?
Yes cat has be n removed and to top it all of my clutch has just slipped so anybody recommend to change flywheel the same time when clutch is done ?
Maybe too many launch modes. You need to see if the flywheel has been overheated and is no longer true.
Okay how can you tell that with a steel ruler isit
Don't really know why your clutch would be slipping, it's usually due to wear and tear or misuse. Only way to really check a flywheel is with a dial indicator once you've removed either the engine or the transmission- a bit of a pia especially on what should be a fairly new car.
Was a new clutch kit & DMF flywheel job now all sorted thanks guys :)
