We've put together two awesome packages for the Fiesta ST from Cobb Tuning. Our kits are designed to fix common issues, improve performance across the board, and provide top shelf quality at a great price. All of our kits are built around Cobb's AccessPort V3 which is hands-down one of the best things you can do for your Fiesta.
Our Stage 1 kit features the Cobb AccessPort V3 bundled with their enhanced rear motor mount, Cobb high flow air filter, and a FREE accessory kit for your AccessPort including an anti-glare cover. The AccessPort allows you to upload pre-tested maps and specific tunes for your Fiesta to improve horsepower, torque, and remove the annoying power limiter in the lower gears. Set the AccessPort in gauge display mode and you can display 6 real time digital gauge layouts complete with datalogging and max/min values. Data is provided by the OEM engine sensors which includes coolant temp, boost pressure, IAT, and more. Know exactly what is going on with your Fiesta's engine at all times and datalog for 3rd party tuners to help them create a badass custom tune.
Click Here to visit this package on our site.
$649 with Free Shipping!
[HR][/HR]
Our Stage 2 kit features the Cobb AccessPort V3 bundled with their enhanced rear motor mount, Cobb high flow air filter, Cobb downpipe, Mountune FMIC intercooler, and Cobb cat-back exhaust. The AccessPort allows you to upload pre-tested maps and specific tunes for your Fiesta to improve horsepower, torque, and remove the annoying power limiter in the lower gears. Set the AccessPort in gauge display mode and you can display 6 real time digital gauge layouts complete with datalogging and max/min values. Data is provided by the OEM engine sensors which includes coolant temp, boost pressure, IAT, and more. Know exactly what is going on with your Fiesta's engine at all times and datalog for 3rd party tuners to help them create a badass custom tune.
The intercooler upgrade is an absolute must have for long term reliability at higher boost pressures. While the OEM cooler will work for a blast or two in a temperate climate, running the car hard such as at a track day, on Saturday night, or just hooning around will surpass it's ability to cool the air. This leads to timing retard, power loss, and will increase the chance for detonation and pre-ignition which can lead to engine failure. Cobb requires an intercooler upgrade for the Stage 2 and Stage 3 maps as well for these very reasons. We include the Mountune unit as it's available and an excellent upgrade to have.
The free flow exhaust not only uncorks some power and torque, but also improves turbo spool even further. For most turbo cars the downpipe is one of the best mods you can perform for increasing engine and turbo efficiency.
The motor mount fixes a common problem area for FWD vehicles, especially the Fiesta ST with all it's torque. A less apparent benefit to the stronger mount is that it reduces the stress on exhaust components which reduces the chance of developing cracks and leaks, as well as the stress to CV joints from additional articulation. Combine that with improved response and less unwanted engine slop and you got yourself an effective mod.
$2599 with Free Shipping!
[HR][/HR]
Our Stage 1 uses the Cobb Stage 1 map above, but our Stage 2 kit uses the Stage 3 map above for an even greater increase in power!
Unfortunately free shipping only applies to the US mainland. For international orders to Canada and other countries we will work with you to achieve the best solution for you in both time and rates. For those of you in Alaska, Puerto Rico, and Hawaii or overseas in deployment areas we will be happy to work with you to get the best rates possible as well.
[HR][/HR]
[HR][/HR]
