Car overheated today after a 30 min idle warming up before I headed out to work. Got 240 on the dash before I noticed so it's not engine killing overheating but it looks like something's up with my fan. I started blasting the heat, pulled out and within 15 mins of driving managed to get it down to 197 which is good. I'm worried about this being intermittent though because when I started driving shit started working, the fan turned on. So either it was a fluke or something in the electrical system for the fan ie a relay fuse or the fan itself is faulty. Anyways, everything works for now. I installed the ba fuel pump finally and it works just fine. I need to get it tuned for the car though as it's adding quite a bit of fuel and having trouble maintaining afr at certain rpms but it's a lot less of a problem than I thought it'd be. I'm gonna be purchasing new charge pipes since I'm not using the tial bov anymore, I'll be purchasing ron's. I'll also be getting the Garrett intercooler because their cores are rated very conservatively and it should be more than sufficient for my goal. I'm also considering purchasing the new swave summit braces, anyone have a review on these? Other than that, my builds pretty much rounded out. I've also figured out how to run e85 on the fiesta and it's not for the faint of heart. For the s280, joe shmoe could buy the pump and run aux and be fine at 340 but the system can't flow enough for full e85 past that, the instructions of the pump indicate this as our fuel line is too small. For us to run this system we need 1 340 in stock hat fuel pump feeding a surge tank running a 340 in the surge tank feeding another external pump with uprated injectors, xdi pump, and aux fuel that's running nothing less than 135 lb injectors or 1400cc. This is a 600 hp capable e85 system and as you can see, it's pretty insane what you need to get that power from the motor on that fuel. Eventually I'll delve into it but I want a reliable 600 hp motor first. I have a reliable 400 up motor so I can't blow it up just yet, it's still my daily
