What is more efficient and produces less carbon emissions? A Gas Furnace or a Heat Pump? Bet you'll get that wrong as most are being told the wrong answer. Take that Heat Pump and subtract another 5% from the listed efficiency. Because the average powerline loss is 5%. Now compare that new efficiency to a high efficiency Gas Furnace. Note I happen to know this number because I had to replace my old 94% efficient furnace with a new one because the control card had failed and it was 30 years old with no new card available. The new furnace cost 9000 dollars and is listed at 96% efficiency. Ah, but you'll say your Heat Pump doesn't produce any Carbon emissions. Did you forget the powerplant that produced your electricity is powered by Natural Gas? BTW, current efficiency for a natural gas powered turbine engine is 35%, so a gas turbine directly powering a generator has pretty poor efficiency. Next up for gas powered generators is a gas boiler (80%) feeding a Steam Turbine (90%) with a Net Efficiency of 72%, still a bit heavy in losses compared to gas furnace. Net result is that Gas is actually more efficient and Greener than Gas Powered Electric. Want to compare your electric water heater to my gas water heater, you'll lose there to. You've got the pesky powerline losses in addition to that poor efficiency for the turbine powering the generator. Actually if you factor that poor turbine efficiency into the net efficiency for an electric car it's quite possible that a gasoline powered auto has a lower Net Carbon Footprint than an electric car. As for why, it's probably the weight of the battery that is the killer. If you want your EV to be truly green that is simple, limit your range and use Solar for re-charging.
Let's look at your heat pump example, which, I truly commend you on as you took the time to trace the whole system. We'll use natural averages and a high-efficiency, mini-split heat pump, like my Mitsubishi H2i's:
1 Unit of Dinosaurs (UoD) * 30% conversion factor (brown -> electricity, lowest rate) * 95% distribution (line loss, average) = .33 Units of Electricity (UoE)
So 1 UoD results in .33 UoE. Pretty bad, huh?. This is why energy providers are standing up so much solar and wind - it's cheaper. But, anyways, I have that .33 UoE and I feed it to my heat pumps:
.33 UoE * 300% (heat pumps pump heat, not create it - for every UoE my heat pumps use they create more than 3 UoH (Units of Heat) = 1 UoH.
Huh.., parity..., but it gets better: my system is a mini-split so it's at least 20% more efficient than forced air:
1 UoE * 120% = 1.2 UoH
Heat pumps are ahead.... then we have to remember that, nationally, we create 61% of our energy burning dinosaurs. The rest comes from renewables and nuclear:
1.2 UoH / 61% (UoD in the energy mix) = 1.97 UoH.
So for every UoD consumed at the source my heat pumps deliver 1.97 UoH. That's pretty significant, esp. considering that it's only going to get better as we introduce more renewable energy to the grid.
But, then, you made a good point, which I'll add my spin to: although local consumption of electricity can be more efficient than local consumption of fossil fuels, it can never be greener that the source of the electricity. Brown grid == brown heat in my house.
Here's a snap shot of my annual consumption and production of electricity:
Year to date, I'm making 61% of the electricity I use. (August was a killer - lots of heat and lots of driving!) I'll use more and generate less in the winter, so let's adjust that to 45% over the whole year, even though, historically, it's going to be greater. And that includes the consumption of my 2 EVs as well. So, now:
1.97 UoH / 55% (energy from the grid) = 3.58 UoH
So, in my particular case, because I can generate the energy for my heat pumps from my roof, I end up with 3.58 UoH for every UoD that is burned at the source for my needs -
my heat setup is over 358% more effective at turning dinosaurs into a comfortable house that is your furnace. And that's not even considering that mini-spits have an additional advantage by being able to dial in the temperature for each room; I don't heat and cool my guest bedroom, basement or garage as well as the rest of the rooms nor do I condition the air as much in my bedroom during the day or my office at night, and that makes a huge difference in my energy consumption, but I can't put a number to it so I'll just include that as a unmeasurable bonus.
As a result I foresee that there will be an energy crash in 8 to 10 years that will take out the power from coast to coast and it will take time and a monumental amount of effort to get the Grid back up and running within a month at best, worst case it could take 6 months.
Come on, that is 100% speculation and not even sensible as there are 2 grid in the US. 3 if you include Texas.
