Lower front strut bolt and nut specs
Port Hueneme
Can anyone help me out and tell me the specs on the lower front strut bolt and nut size and specs. Dealer wants $15 for each bolt and comes in a 4 pack so I'm trying to find them locally somewhere else but need the specs. Thanks in advance!!
westcoaST
Corona
Try Tasca com, or fordparts com to check the price for yourself.
Sent from my SM-G935V using Tapatalk
D
Port Hueneme
Thanks [MENTION=411]westcoaST[/MENTION] I was trying to get them locally and not wait but I guess I'll have to.
Why not just use them again; everyone else does.
Dave
D
Port Hueneme
Dave
I think I've taken them off and put them back on so many times I'm wearing them out lol. I torqued them down to factory specs and I went to the dealership today for something else and they told me they were loose so they tighten them back down. I'm just buying new ones as a precautionary measure.
LilPartyBox
I always replace them. The risk is real and not worth saving the minimal cost of new bolts.
BRGT350
Grand Haven
I have replaced them and also reused them on different Fiestas. I would suggest using only Ford hardware if you are going to replace them. Never ever ever ever ever use hardware from a local hardware store. The Ford fasteners are designed specifically for the application. The shank design is unique, plus the coating and material are also unique. The torque values won't be correct if you don't have the exact coatings. I spent 4 years in suspension engineering and most of that time was working with fasteners.
If you do happen to reuse them, be sure to torque them exactly as specified. I added a little blue Loctite to all of my fasteners. I also added a special product called Torque Seal that you place on the outside of the fastener and it cracks if the fastener moves. This allows for visual inspection of the joint to make sure it is tight. I check mine when I wash the car since the seal is visible from the outside. If you have followed the torque procedure properly and get a loose joint, replace the fasteners. Also, be aware that anti-seize changes the torque. Different types of anti-seize and different types of fastener coatings result in either a lower clamp or higher clamp load based on a given torque.
The best bet is to always use new fasteners and follow the proper procedure.
