So my car's MFT has stopped making the beep noise when touching buttons on the screen. I didn't turn it off and it says it is turned on according to my MFT's settings. But no beeps even after restarting the car. What gives?
And just a minor rant. Why is there not a volume control for the touch beep? I would've liked to turn it down but not off.
Other random things.
I've noticed that the turn signal doesn't keep a consistent tempo. It subtly slows down and speeds up. It's not that big a deal and I chalk it up to part of the car's character. Besides, I'm sure it is an issue the dealership will say they can't reproduce.
And the turn signal noise is very quiet. Can barely hear it when just idling.
The ebrake doesn't grab at all until pulled all the way back to the last notch. And even then it won't hold the car on a slight incline without the car being in gear.
The other day the MFT locked up when trying to select a playlist on my iPhone. Hitting the source button returned the MFT to the home screen but didn't fix the issue. Restarting the car fixed it.
Also, my map goes schizophrenic at dusk continuously switching back and forth between day and night mode. And with the slow map refresh rate it makes it frustrating trying to actually use the map during that time. I thought I turned off the auto-dimming but it still seems to do it.
Not sure if there is a fix for any of these issues. But it felt good to rant and see if anyone else has had the same issues.
