OEM Clutch & Flywheel (Parts Needed?)
JDG
JDG
Conshohocken, PA
Thread Starter #21
Thanks for posting this. [thumb]
I knew that they used an AP pressure plate/cover, but did not realize that LUK supplied the friction disc.
So the clutch has LUK and AP stamped on there. Does one company own the other?
JDG
JDG
Conshohocken, PA
Quisp
Davenport
New York
Is there anything to worry about when replacing the race that goes under the outer seal???
Quisp
Davenport
#29
No race there. Just be careful to not gouge the housing when removing the seal.
Sent from my SM-A205U1 using Tapatalk
Paramus, NJ, USA
#32
Okay so I dropped it without taking the sub frame out. I did remove the cowl, as I used an engine support bar to help me. I had to disconnect my downpipe from my 3” CPE Nexus exhaust to get to that “hidden” transmission mount bolt. It came out very easy for me 😜
Chimayo, NM, USA
#33
I se
Top box is the Slave Cylinder, Middle is the Clutch, Bottom is the Dual Mass Flywheel
Sent from my SM-G973U using Tapatalk
I see you have output shaft seals in the pic. Should this be done as well? I ordered a transmission from puma speed so wondering if I should replace the seals or if it’s fine.
Chimayo, NM, USA
Chimayo, NM, USA
#37
