This did not work.
Okay I think I found something that will work to orient the oil filter to make it easier to replace and even upgrade to a larger filter FL-1A. Part is M-6880-A50. The gasket is 72mm OD / 63mm ID gasket. The FL400s is 70.4mm OD /61.2mm ID.
This unit only changes the orientation which is all I need. Now I am sure the 90 will be not enough to clear the hoses, but I also plan to add a sandwich plate to get the temp and pressure. I think this would add treh required distance to clear the hoses.
Next oil change I will take some measurements to see how everything fits. Will report back when I have more details. Anyone that has input please share.
