Overheating - Fiesta ST ( A/C HOT While Idle)
Dearborn
Hello All,
Running into Issues with my 2015 Fiesta ST
A/C blows hot at idle ... Cold while driving
Coolant Temps Stay at 187 - 192 while driving
Coolant Temps rise to 240 - 250 at idle (Overheating)
While under the hood looking, it seems like the cooling fan isn't spinning.
I'm assuming that is the issue.
Checked the Fuses none are blown.
redmoe
Phoenix
Sounds like the fan motor or the fan controller may have died. If the ac cools down again when you are moving that indicates the the heat exchanger is not getting enough air flow to function properly. Obviously the same for engine coolant temps.
Did you have the fan relay replaced?
I know the problem (TSB/recall/whatever) was with/for EARLY '16 builds, but still worth a try. ;)
me32
fairfield
You did make sure to have the AC on when checking the fan under the hood?
S
Dearborn
Checked the fan itself, checked all the fuses. Where is the fan controller? Just to make sure im not overlooking it.
Direct power the fan if possible with a lawn and garden battery with alligator leads.[clap]
