Hey folks-alright! We are excited to finally release our Fiesta ST Rear Torsion bar/rear torsion beam stiffener. After many miles of testing and info gathered, both on/off the racetrack in several different twist beam platforms over many years we're ready to start production! Special thanks to Dave and those who've helped prototype/put miles on the products! The results are impressive and we're able to offer the product with different stiffness rates to tailor/suit individual performance needs. First the benefits!
~Improved stability at higher speeds in both straightline and corners over uneven surfaces!
~Reduces rear toe change over bumps/curbing/helps with rear bump steer!
~Improved balance helping both turn in and mid corner grip!
~Helps reduce dreaded FWD understeer!!!
~Will enhance both spirited Daily Drivers, Track and Race cars alike!
For most folks improving grip is important, however, using parts that haven't been properly developed/tested often times leads to disappointment and can create complications. We've taken our time with this platform/product development and really will only produce products that improve the driving experience. The design we've chosen for the rear twist beam offers maximum effectiveness while still being extremely easy to install with basic tools. The bar requires just a 3/4" wrench or socket and installs in a few minutes!
As with most of our products we've chosen Chromoly because of it's strength to weight ratio. Being 3X more rigid then mild steel (and 10X as strong as aluminum at the same thickness) allows us to design a much lighter/stronger product. We're also able to "tune" the product by using different lengths/thicknesses of material to create something completely unique for the Fiesta ST platform! We've chosen to use a billet threaded/machined pin as our center capture point offering maximum holding strength as the bar will see tremendous loads during cornering---We've also radiused the top to perfectly mate to the underside of the torsion beam as it's not flat up there! Maximum contact insures that the bar will stay tight, the torsion beam hole will not "oval" out after time, and the bar won't lose its effectiveness. Additionally we've added lower rear stays that "wedge" into the beam offering additional contact points which take stress/reduce the load on the hardware. By having 3 contact points per side, we're able to maximize the effectiveness of the torsion bar! Additionally we've machined Acetal/Delrin bushings at the lower two contact points which eliminate the need to drill a hole through the torsion beam in the car---The beam is not soft material---it's actually very tough and adding holes reduce effectiveness, the beams surface area, and can create additional trouble if not drilled straight/down the line.
The pics below are of the prototype after testing---the prototype was just coated black and we used softer white Delrin to determine wear, if any, and for visual inspection without having to remove the bar. The rear torsion bars will be powdercoated the same anthracite color we use throughout our line now and we'll be using black Acetal/Delrin with a much harder durometer for the production product! Additionally it will come with Grade 8 fine thread hardware and be available in two different rates---the STREET version and RACE version!!!
As with most of our products, we are excited to offer a pre-buy/sale at a discounted price with free shipping! The product will retail for $139 plus shipping, however, through Labor Day weekend, we will offer it for $125 shipped to your door! Please PM me here with your Paypal information/version choice and we'll get an invoice to you immediately! We're scheduling production over the next few weeks---we're currently having pieces machined and look to have product shipping out next month! This will be a HUGE improvement for the overall balance and handling-enjoy!!!
