So I am getting misfirin, but only when I'm using the engine for downhill breaking. I am just starting the break in on my new engine after a catastrophic piston failure. I have a brand new Ford long block and I have my TT S280 installed as well as a 180 thermostat, Mountune Radiator, Whoosh FMIC and intake & crossover pipes. I have a Dizzy base tune installed for the break in so I don't get any codes from using the TT S280. The base tune is limited in boost to the waste gate spring which is keeping the boost to under 14 psi. I also installed the one heat range colder NGK 6510 plugs. I'm wondering if the fact the engine is running 15 degrees cooler on limited boost and ambient air temp is about 55F that the plugs may be too cold for the conditions? They don't appear to be fouled and they are dry. Any ideas????
