I've installed both and noticed a few things and question one or two.
I notice the solid feeling when pulling off the line the most. I love it. It appears, until I drive it more, that the torque steer is less.
I notice the passenger directions picture ADDING the insert and it completely fills in the space.
Has anybody removed the passenger OE rubber and if so, was the poly alone too hard for it to hit up against under load?
Would removing the OE lessen the NVH or is the Trans insert a partial culprit?
I forgot that I had read the thread to use a zip tie instead of the o-ring, so I have to go back and switch it later. Does it fail by age or stress more?
Anything else to know?
(Doing the work was almost the same to replacing them on my Mazda 5 2.3L, including the battery box location/removal. Those weak-assed OE mounts were bad when I bought the car used, but I had no idea. I thought it was the tranny for over a year or two. I replaced them all and wow! Night and day. They will go bad again eventually, but I'd like to have a hi-perf option for one or two of them.)
