I got the one listed above from Ron @ Whoosh, the one that does work but has the arrows on it. I will try again. I just dont want to damage my soft dash material when removing it. Thanks all for the tips.
all the push buttons "fit" the same
make sure you are using the pry tool to pop out the entire plastic bezel and button, NOT just the button.
once you pop the button and bezel out of the dash, simple unplug and swap the button in the bezel, then push it back in the dash.
Both start buttons we offer "fit" the Fiesta
The Red illuminated button is plug and play works 100% as the stock Fiesta button does
The BLUE illuminated button is really for the Focus, the electronics are slightly different so in this case the top cap/lense has to be swapped from the BLUE illuminated switch to your stock push button. Super easy mod either way you go
