Really Should Stop Modifying my Daily Driver into a Track Car
dhminer
Burlington, NC, USA
Well, I got it in place and locked down. Yeah that was a pain in the ass. Wonder why its so far out of spec on the cable position? So far with no cable adjustment I have all gears, with the engine not running. That is a plus.
I don’t know why it’s so far off, but I have easy access to all gears and it’s straight without any adjustment except for the centering knobs. I’m not questioning it lol. If it breaks I’ll locate a CAE shifter to replace coolerworx
Fusion Works
Fusion Works
Huntsville, AL, USA
Thread Starter #185
Yeah with everything bolted down tight, I have all gears and such with the car in neutral, not running me not holding the clutch pedal down. Haven't done any of the OEM centering adjustments yet.
To me the only major improvement I would make to this shifter assembly, is the adding an extension to the forward back bell crank to move the top ball stud closer to the center of the assmembly to straighten the overall angle of that linkage rod.
Fusion Works
Fusion Works
Huntsville, AL, USA
Thread Starter #187
Not touching it for now. HAHA. Would like to drive my car once before next season. Its cold and rainy here, who knows when that will stop.
Woods247
Atl
Come to RA and be miserable with me in February for two days. I’ll get you a fat discount.
Woods247
Atl
That we might could do. Maybe my trailer will be free by then.
It’s actually Barber again not RA. We do have back to back days in December at AMP and Road Atlanta but I doubt my car will be ready by then. Should be good for Barber though. February will be COLD
Fusion Works
Fusion Works
Huntsville, AL, USA
Thread Starter #191
Yeah I am questioning the logic of anything in Feb. HAHA. Its either gonna be pleasant and 70deg or its gonna be snowing and 9 deg. Alabama in the winter is never guaranteed.
Fusion Works
Fusion Works
Huntsville, AL, USA
Thread Starter #192
Well this was an incredible pain in the ass and way more time than it should be. IMG_3981.jpeg 73017052893__B8469A98-CD6A-4FAE-9574-CADB7A383525.jpeg
The trans mount studs are pressed in and crimped in place as far I can tell. Removing them was a massive pain. I will let ya’ll guess why I removed them.
This is the final iteration of my ECU and fuse mounting plate is coming along. This will clean up all of the battery box area
72913992221__D5B5F996-953D-4589-AFF1-A88E13CA46D3.jpeg 72905127692__E8DAE53B-199D-4D5B-A893-512ED6E27A42.jpeg
Fusion Works
Fusion Works
Huntsville, AL, USA
Thread Starter #194
Ok its been a busy while since I have updated this, but a lot of parts have been made in order to get the car on track for Gridlife.
I mostly finished the battery relocation and wiring clean up in the engine bay. I need to run one wire to the back where the battery is to connect all the battery sensors directly to the battery for now they are just tied up in the engine bay not connected. However I have no check engine light because of it either.
73422859835__3C3FD33D-4A5F-4DD8-9261-69F8F0222BA1.JPEG 73422861204__42629AD2-99A9-49C5-A78C-4BB5FC3B147C.JPEG
I spent a ton of time on lowering the engine. It was a ridiculous amount of work for probably a minimal gain. I made custom 1in stainless spacer studs to go into the OEM transmission mount on the case. Removing those OEM studs was a massive pain in the ass, they are cast in place I think.
IMG_3981.JPEG 73170698132__4384968C-488A-47CB-AF6F-FBF7F6907E9D.JPEG 73195541809__8C2136B8-421F-477B-9A66-39CCFE4AD5BC.JPEG 73196304918__B4283990-F0D7-4A2D-98CC-128A084B9EE4.JPEG
The studs are 17-4 stainless, cuz its stupid strong and I don't have to deal with zinc plating it. These in conjunction with some aluminum spacers and longer studs on the drivers side bracket worked out pretty well. I had to build a custom dog bone and change the angle on my down pipe to rotate it up into the tunnel, which I wanted to do anyways. Doing that cleaned up the exhaust I always felt hung down to far.
Fusion Works
Fusion Works
Huntsville, AL, USA
Thread Starter #195
Some more pics of the electrical clean up:
There are still the proper fuses setup for the main fuse box and the power steering. I still need to attach the huge 450amp fuse at the battery, but I have never had an issue with the run from the front to the back so its not a huge priority.
The two little wires are the transponder wires that run up from the splitter where I have it mounted. They get connected to power and ground when I am running an event that has timing and scoring.
Fusion Works
Fusion Works
Huntsville, AL, USA
Thread Starter #196
Also built and installed all the proper safety equipment. Built the roll bar to SCCA regs, but its all Docol R8 tubing that was TIG welded with the proper filler material. Its bolt in, because I have a sunroof and I probably will have to remove the damn thing in the future to fix a water leak. I can also now get it powder coated. I welded plates to the floor with weld nuts behind them. Then bolt the roll bar to those plates. They tie into much stronger chassis points than the sheetmetal of the floor and the fender wells. I actually reused one of the rear seat anchor bolts along with the three other mounting bolts in the rear down legs. I haven't weighed it but its probably about 45lbs.
73440510135__94E65D79-E276-4520-8613-C4A27D80AEDF.JPEG 73449217650__0AD83F46-013D-4720-ACE2-A3ED07027A93.JPEG IMG_4267.JPEG IMG_4268.JPEG IMG_4270.JPEG IMG_4271.JPEG
Fusion Works
Fusion Works
Huntsville, AL, USA
Thread Starter #197
While building the roll bar, I made some lightweight seat mounts for the Racetech seat and Racequip harnesses. One thing I like about this seat are the proper holes for running a real six point harness the way it should be run. So many modern seats are actually designed for 5pt harnesses which aren't as safe in my opinion. These mounts weigh a third of what those stupid Planted seat bases weigh. The side mounts were some I designed for an RX8. They sorta worked here, but after being on track my butt was too low and I had to put a towel in the seat to get my eyes up above the wheel rim. I think I will add a hole to use a different style side plate to get my butt up a little higher for better visibility.
73414511442__9E55C9FB-FC7A-4FD1-ACE6-1EA5BE282682.JPEG 73414512261__CD9D934A-448D-40AB-A25A-1A00EC2172FF.JPEG 73414582635__295607FF-3960-43C7-BACE-303AAC570E94.JPEG 73414584058__ADDE2237-F563-4AD1-B6DC-08CAB77ACBAB.JPEG IMG_4272.JPEG
