All I want to know is if anyone has put subs in the rear door, I found some "SKAR-PAX 6.5 Mid-range Speakers" at pick n pull for 15 bucks the other day and I was just curious if anyone else has done it. I'm gonna run a LOC from glove box to a amp mounted somewhere in the trunk. Not sure on placement yet. Anyways I already have the speakers retro fitted to the oe speaker housing for the oe clip connecters and was wondering once I add the amp do I just run the output directly from amp or use a t-connector. Also t connecter at LOC-to-headunit? Or just run input directly to LOC since I'll be using amp.
Ps. I've been using speakers without amp they work and all but amp will give it the power it desperately needs. Basically I just want to know best way to set up the LOC because I'm very aware of the bass cut off at certain frequencies.
PSS. I had them in the back before I was informed most of the sound goes to front and since I didn't have amp at the time I moved them to the front. I've done the frequency sound test. 65-120hz is where they sound best.
