Spring & Damper fans rejoyce! Bilstein B8 dampers are now "at inquiry" on the EU site!
MOFiST
Adelaide
I'm curious why for the fronts it says "twintube" but for rear it says "monotube". Perhaps a typo as I thought all B8's were monotube design.
But bring it on please Bilstein!
LT Berzerker
Any way to get these from a stateside distributor?
Sent from my Nexus 6 using Tapatalk
Louisville
Wondering if we will see these stateside? Maybe @mountune will do a clubsport for the FiST.
Are these rebound and compression adjustable, or are they just a very good street upgrade over the stockers, valved for a slightly higher rate spring than stock??
Bilstein HDs were nothing to write home about in the 4th gen f body world, WHY I'm asking.
kevinatfms
Germantown
Any word on this? Looking for a replacement set of dampers without having to buy the coil over version. Wish they would develop a replacement damper specific for the ST and not a generic damper for all Fiesta's as the springs are differing rates. If they can match the ST spring to a monotube damper it would be useful.
kevinatfms
Germantown
i assume that the sports and str.t's will fit and more than likely be fine for a daily driver. Ill probably end up going with the str.t's since i dont need the adjustment.
KKaWing
KKaWing
Somewhere
Thread Starter #14
Bilstein USA doesn't have email. You'll have to call them directly.
Do we know for fact that the Koni Sports are valved to a range for the lower rate 'base' Fiesta springs, or do they 'cover' the factory ST springs AND maybe even some slightly higher rate (Swift for example) in their set compression, and adjustable rebound 'range' of valving? [dunno]
I think that Lee Grimes needs to be called about this tomorrow. [wink]
kevinatfms
Germantown
Anyone heard any update on this? Any chance they are bringing them to the US market? I want the regular Bilstiens without the coilover adjustment(staying with stock springs).
kevinatfms
Germantown
Will be ordering immediately. This is awesome. Bilstein listened!
koozy
Los Angeles, CA, USA
Rear German Bilstein B8 shocks paired with German ST Springs. No issues, noises, etc. I used the hardware that came with the Bilsteins. Front struts going on soon, stay tooned.
on the ground.
OE shock rod diameter is 12.5mm, Bilstein rod diameter is 14mm
