Stay plugged in or not with Accessport?
San Marcos
What do most of you guys do? Do you like to leave your Accessport plugged in and monitor different things, or do you prefer to load the map onto your ECU and then take out your Accessport?
ryst
Grand Rapids
I leave my AP mounted to view readings. My current setup is 5 gauges: Boost (with graph), compressor temp, charge temp, ignition correction and oil temp
Other readings I have used or swap out are intake air temp, AFR, and coolant temp
Charlotte
5 guage setup myself, Boost with graph, ignition correction, knock for cyl 4, oil temp, coolant temp. Will probably take coolant off and swap with something else, as I did have my radiator pressure checked just to be sure it wasn't one of the unfortunate defect ones.
stuntdoogie
I dont plug mine in anymore especially for short rides. Tired of connectiing and disconnecting. I want real guages already.
