Stock airbox mods
Cape Town
Hi guys. I know, another "airbox" thread [:o]
Has anyone removed the snorkel (highlighted in blue) and noticed an improvement in sound?
Can the bit highlighted in red be detached from the box or would it need to be cut out?
I have a k&n panel filter and would like to improve the sound a bit without cutting up the airbox.
Thanks
Sydney
During Australian winter i remove the s bend as the 2 90 degrees bends restrict air flow, Aussie summer is to hot to do this. I run a Mountune lower air box with bottom feed going directly to front of car near fog light, then for track days ive created a 90mm side air entry directly feeding from a modified head light. All scenarios have produced a louder and varying note difference with improved consistency of my performance.
Sent from my SM-G900I using Tapatalk
georgie
Cape Town
That looks awesome man! My problem is with the warranty/maintenance plan. I tried to get a stock box from the dealer so I could modify that one, but they want R2400 ($170) [rofl]
Rhinopolis
Houston
I drilled many "small" holes in to the bottom of the box and in to the sides, to help the box better breathe and so that more incoming cooler air could make its way to my Cobb filter. If you didn't know, the Cobb Filter utilizes the stock airbox.
georgie
Cape Town
I would drill holes but am worried the dealer might notice. How was the sound compared to a sealed box?
Rhinopolis
Houston
No change in sound with the Cobb or in drilling holes in to the air box. I purchased a 2J cowl intake second hand from a guy in Houston who daily drives his car, and the 2J was too aggressive for him. With that intake I will definitely notice a change in sound.
georgie
Cape Town
Thanks for clearing that up. I'll just leave it stock for now.
Aftermarket intakes work out to way too much money here in SA
R4000 - R7000 ($280 - $500)
TUX15ST
SOUTH BOUND BROOK
Your never going to be happy with the intake noise of a stock intake, however it is one of the most effective at actually providing cold air
Manassas
Just slap on a MAF adapter and cone filter if you are looking for sounds. Easy to swap back to the stock box too.
OffTheWall503
Memphis, TN
You'll get sound but you're actually reducing performance due to the air being hotter, the stock airbox does a good job at delivering cool air through the air dam in the front grille.
Manassas
Yes i know, this is why i am running a drop in only [like]. Butt if hes looking for pure sound and doesnt care for performance then that would be the cheapest way to go, unless he wants a BOV spacer?
georgie
Cape Town
Thread Starter #15
Thanks for all the feedback guys.
There is a maf housing and cone combo available for R1500 ($105) locally. Where would I secure the cone filter though? Could I leave the bottom half of the airbox in place and strap it to that somehow? Not too keen on a filter just hanging from the maf like like the pic below.
As far as performance is concerned, i am not looking to gain, but would also not like to lose any either.
georgie
Cape Town
Thread Starter #16
A Forge BOV spacer is around R1000 ($70)
Is that the better option for sound? Can it be picked up when the dealer logs the car?
Not too sure about just increasing the blow off sound either, would like to have a more aggressive engine note as well.
BRGT350
Grand Haven
Fiesta SFE 1.0L air box modification by Bryan Redeker, on Flickr
I added a velocity stack to the bottom and side of the factory lower airbox on my ST and my brother's 1.0L. The addition of both items seem to be working fine and the velocity stacks smooth out the airflow entering the airbox and amplify the sound coming back out during off-throttle boost purge.
AncaSTer, Ontario
KKaWing
Somewhere
Wow! The North American and European versions of the airbox are quite different (your image vs. BRGT350's)
The airbox is actually the same, I bought one from the UK to screw around with. It fits perfectly. The difference is actually the radiator shroud part. NA shrouds dip downwards, EU ones are raised. I found this out when I bought Sico Developement's intake "heat shield". It still fits though, just has the part over the radiator hose floating.
georgie
Cape Town
Thread Starter #20
Thats what I would like to do, trying to get a second airbox to mess with though. Looks great!
